Activity › Forums › Maxon Cinema 4D › missing render item, and passes…
  • missing render item, and passes…
    Posted by Aaron Martinez on August 19, 2007 at 8:01 am
    hallo i have a couple questions…i am rendereing a litte tiff sequence. and for some odd reason a couple of my objects are not properly rendering. i have a couple text objects. and they are grouped under other objects, but the text doesnt show up in the render. i made it editable and one is now there the other is still not there…i find it weird…
    my next question was, is it possible to render passes with the toon effect on. i mean i am new to this whole 3d thing but what i wanted to do was render a toon sequence, throw it into after effects and maybe touch up the shadows and select the exact colors that i need…is that possible? when i go to multi pass in the render i select post effects, and in post effects i select toon and sketch, and highlights. i get a good highlight sequence, but i do not get a toon…i would appreciate any help…thanks…
    aaron
    Aaron Martinez replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
