Activity › Forums › Adobe After Effects › Missing presets in AE CS5.
  • Missing presets in AE CS5.
    Posted by Chris Lee on April 12, 2013 at 1:15 am
    Hi, so I’m brand new to After Effects and I’m trying to add the “rotate over time” animation preset to a title. But whenever I do, it says “this favorite contains 1 reference to a missing effect. Please install following effect to restore reference (“transform”). Now, it’s a little concerning because when I open up my finder and look for it under the presets folder, it’s right there. I’ve tried to backtrack, restart, etc, but I keep getting the same error message. Any help?
    Specs: 2010 17 in mbp. OSX10.8, 2.53 ghz i5. 8 gb RAM, 500 gb. I’m on AE 10.0.0.458.
    Todd Kopriva replied 13 years, 5 months ago 3 Members · 2 Replies
  • John Cuevas
    April 12, 2013 at 12:52 pm
    Did you update your version of AE to the latest version. I just applied the preset and it worked fine.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Todd Kopriva
    April 12, 2013 at 9:02 pm
    Apply the most recent updates. There have been two bug-fix updates to CS5, and you haven’t installed them. You should be on 10.0.2.
    An even bigger concern is that you appear to be missing a standard effect plug-in: Transform.
    So, actually, you should re-install After Effects to make sure that you’ve installed all of the effects and then update to get the bug fixes.
    After Effects team blog
