Activity Forums Adobe Premiere Pro Missing Lower third templates in Essential Graphics panel
  • Missing Lower third templates in Essential Graphics panel
    Posted by Leonard Frankford on September 6, 2023 at 6:58 pm
    I am using Premiere 23.6. My colleague in our office (although we are both working from home) is still on 23.2, but her Essential Graphics panel contains several, if not dozens of lower third graphics in the free My Templates Libraries/All that I do not have and have never seen. I wanted to use one of them but I don’t have it. They are named 1_RS_Black and White, 1_RS_Extreme (that’s the one I like), etc. I have much older graphics. Why don’t I have the same templates that she has and how do I get them? Thank you.
    Mads Nybo jørgensen
    replied 2 years, 11 months ago
    2 Members · 3 Replies
    September 6, 2023 at 11:21 pm
    Hey Leonard,
    Adobe is making a few changes around managing graphics.
    This a change that happened in v23.3.
    Don’t know if it is relevant, but sharing anyway as it is a change that has happened between the two versions that you and your colleague are running:
    Import MOGRTs more easily
    When importing Motion Graphics templates, Premiere Pro displays a dialog that explains that the template will be stored under the Browse tab in the Essential Graphics panel (and not in the Project panel).
    Learn more about installing and using Motion Graphics templates in Premiere Pro.
    Adobe has a way of making changes that are hidden away, unless you read the small print…
    I suspect there is more “tweaks” coming.
    Also, have you tried to search the Adobe Stock Library via your web-browser?
    https://stock.adobe.com/uk/search/templates
  • Leonard Frankford
    September 8, 2023 at 5:47 pm
    Hey Mads,
    Thanks for your reply. I did a little more digging and discovered these were a set of 15 free mogrts from Pond 5, or more specifically RocketStock via Pond 5. Here is the link if anyone else wants to download them: https://blog.pond5.com/78798-free-after-effects-templates-15-free-animated-lower-thirds-premiere/
    Leonard
    September 11, 2023 at 9:26 am
    Hey Leonard,
    The bane of our life’s, when the “supplier” of an asset, cannot bring themselves to add their name or identifier to the media/graphic asset.
    Pure guess work, and in your case, one might start at Pond 5, but ends up at Premium Beats to make the down-load from there.
    And, you can’t have a go at your colleague for not naming the file, as the “name” of supplier does not often carry through inside the project, and often “Lower Thirds” involves a last minute scramble before delivering to client/broadcast.
    Well done for finding them – and thank you for sharing.
