Activity › Forums › Panasonic Cameras › Missing LastClip.txt file from P2 card, how to import into FCP?
  • Missing LastClip.txt file from P2 card, how to import into FCP?
    Posted by Atdiem on August 16, 2007 at 7:59 pm
    Hello All,
    I’m working with the Panasonic HVX using P2 cards. I have a drive with improperly ingested P2 cards on it. Specifically, instead of copying the contents card AND the LastClip.txt file, only the contents were copied over to a harddrive. I’ve tried importing them into FCP by copying LastClip.txt files from the same cards used on that shoot and tried “cheating the system” but the “P2 volume was unrecognized.” I tried using the Voltaic program (which transfers AVCHD files into quicktimes) but it does not recognize the mxf video file format–only the mts and m2ts files can be imported. I know the differences between AVCHD and P2 but I thought it was worth a shot as that program ignores the AVCHD text file. Does anyone know of a similar program that might ignore the P2 text file and converts to HD quicktimes. Or am I just dreaming? Any other suggestions out there? Thanks so much in advance for your help and time reading this request.
    Best,
    ~A.
    Arthur Luhn replied 19 years, 1 month ago 3 Members · 2 Replies
