Activity › Forums › Avid Media Composer › Missing Keycode Above Source Monitor in 3perf Project
  • Missing Keycode Above Source Monitor in 3perf Project
    Posted by Matthew Schneider on November 14, 2005 at 4:43 pm
    All,
    On several different systems, I’m noticing that Keycode info is missing in 2 places: above the Source Monitor, and within bins for subclips. I’ve seen this on several different systems and in several different projects. These various projects all happen to be 3perf projects. If you open the same bin in a 4perf project, you do get the Keycode to appear above the Source Monitor, though it is still missing from subclips in the bin.
    The data however is certainly there: if pull lists, the keycode is correct. If you match frame to the parent master clip, the data is there. It’s just not visible within the bin for source clips, and either greyed out or absent from within the Source Monitor info pull down menus.
    Systems in question are either 5.x Meridien Symphony systems or 12.x Meridien Media Composers. Haven’t looked just yet in XProHD or MCAHD just yet.
    Bug perhaps? Known limitation? Or do I need to review my documentation. 😉
    Matt Schneider
    PostWorks, New York Soho
    Matthew Schneider replied 20 years, 10 months ago 2 Members · 2 Replies
  • Michael Phillips
    November 14, 2005 at 10:49 pm
    That is a version limitation. Lists are fine but you cannot see KeyKode metadata above monitors or subclips. This was completely rewritten for Xpress Pro and Adrenaline and can now be displayed everywhere – just like 4 perf.
    Michael
  • Matthew Schneider
    November 15, 2005 at 3:24 pm
    Got it. Many thanks Michael.
    Best,
    Matt
