Activity Forums DaVinci Resolve missing handles in power window
  • missing handles in power window
    Posted by Adam Chesbrough on December 11, 2013 at 10:28 pm
    I am watching a tutorial and when a power window is added to a node the shape appears in the viewer. I do not get the shape nor do I have control over the power window mask. I thought it was a “view” option but I can’t find it anywhere. Where the power window is supposed to be there is a layer name column. Im missing something easy I think
    Macbook Pro Retina: 2.6GHZ i7, 16GB RAM 1600MHz DDR3, GT 650M 1GB RAM
    Hackintosh (Sandy Bridge): i5 2500, 16GB 1333MHz DDR3, Nvidia GT640 2GB RAM
    OWC 4TB RAID0 (using esata)
    Tempo SATA Pro ExpressCard/34 (6Gb/s)
    Echo ExpressCard Pro Thunderbolt Adapter
    Dwaine Maggart replied 12 years, 9 months ago 3 Members · 3 Replies
  • Glenn Sakatch
    December 12, 2013 at 2:49 pm
    First things first. In the screen shot you provided, you have not picked a window yet.
    You have to select “on” next to 1 or more of you window shapes.
    Glenn
  • Adam Chesbrough
    December 12, 2013 at 2:51 pm
    Yes I have done that as well as picked on next to a bunch of them. I have attempted on while all different does are selected as well. The screen shot was just to show the area where the mask should appear and instead I have a the “name” column (I have also named them to see if it switches after I name a power mask…nothing happens.
  • Dwaine Maggart
    December 12, 2013 at 4:54 pm
    View menu / Window Outline > On
    Dwaine Maggart
    Blackmagic Design DaVinci Support
