Activity Forums Blackmagic Design Missing Genlock ON/OFF setting on Decklink Control Panel for legacy Decklink Extreme HD board
  • Missing Genlock ON/OFF setting on Decklink Control Panel for legacy Decklink Extreme HD board
    Posted by Rich Rubin on August 17, 2011 at 9:36 am
    I’m can’t turn on GENLOCK from the REF IN BNC connector on a legacy Decklink HD Extreme board. Can’t find the GENLOCK check-box on any Decklink Control Panel menus. Will it only appear with a certain drivers?….If so, which version. I’m using it for a character generator that must receive black-burst for sync. Please help….Thanks.
    Rich Rubin
    Mobile Studios, Inc.
    Boca Raton, Florida
    Warren James replied 14 years, 4 months ago 3 Members · 3 Replies
  • Joshua Helling
    August 17, 2011 at 6:35 pm
    There is no genlock On/Off toggle on any of our boards. Basically how it works is if reference is detected in the same format as the output of the board, then the output will be genlocked. If not, the reference is ignored.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Rich Rubin
    August 17, 2011 at 7:22 pm
    Thanks Joshua — The problem turned out to be a bad cable and the black-burst signal to REF IN is locking the signal out of the card fine.
    Regards,
    Rich
    Rich Rubin
    Boca Raton, Florida
  • Warren James
    April 23, 2012 at 3:14 pm
    Sorry to bump this thread but is concerning exactly what I am looking at.
    I am working with the Decklink SDK and the behavior of the card with genlock stops part of my application working.
    Is there anyway that you can tell if the card is locking from the ref in or locking from the signal itself?
    I am using the card to check that the genlock on the piece of equipment that I’m capturing from is working.
