Activity Forums Apple Final Cut Pro Legacy missing FxPlug (SmoothCam etc) plugins
  • missing FxPlug (SmoothCam etc) plugins
    Posted by Brad Bussé on February 1, 2011 at 11:13 pm
    My FxPlugs have gone missing. I had this problem a couple of years ago and got it fixed. I see in an older post, someone provided a .sit with those plugins, but it’s from a couple of years ago, so I assume those are from FCS2. I found a post on the Apple site which said to run in Terminal; “open /Volumes/Final Cut Studio/Installer/Packages/ProAppsEffects.pkg” but that must also be for FCS2 since the FCS3 disk is entitled “Final Cut Studio Install”. Can someone tell me the proper command string to extract and install the FxPlug filters for FCS3?
    Harry Dawson replied 13 years, 7 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    February 1, 2011 at 11:57 pm
    Sure they really aren’t there? (you would have had to have trashed them, did you?) Check the setting in the bottom of the Effects Menu to see if “all” effects are set to be available.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Brad Bussé
    February 2, 2011 at 6:00 pm
    I did set all effects to be available. There’s literally nothing in the FxPlug folder. This is a problem that I’ve encountered before. I guess it’s being wiped out by another installation, like a ProApps update, or when installing either Quicktime 7 from the Snow Leopard disc (which I recently did, after FCS was installed), or from installing either Magic Bullet Looks Suite or Trapcode Suite (both of which were also installed recently).
  • Jerry Hofmann
    February 2, 2011 at 6:15 pm
    I don’t have a lot of third party plug ins, so they “might” be trashing those, but I sure don’t think they should… the Apple updates definintely did NOT trash them… had they done so, we’d all see the problem.
    I think you need to reinstall FCP quite frankly to get it right.
    Jerry
    Current DVD:
  • John Cromwell
    August 11, 2011 at 6:31 am
    I had used smoothcam previously then I just installed snow leopard and now no smoothcam filter and the fxplug folder is empty. I haven’t installed anything else, plugins etc, so it must be the mac, yeah?
  • Harry Dawson
    January 13, 2013 at 4:32 am
    Just installed Final Cut Studio in new tower (12 core, 64 gig RAM) and smoothcam and vignette are missing from the video effects folder. where are they and how do I get them back?
    Harry
