Activity Forums Blackmagic Design Missing frames when recording to Quicktime with Decklink HD
  • Missing frames when recording to Quicktime with Decklink HD
    Posted by Dirk Dejonghe on August 17, 2011 at 2:43 pm
    I am recording SDI coming from telecine. On several occasions I have had missing frames, about 24-30 frames long in the middle of a sequence; no warning given by Decklink.
    I recorded SD PAL to Quicktime ProresHQ 422. The RAID0 disks (2ea Constellation 2TB) were recently changed but make no difference.
    The clip should be continuous, usually about 20-30 minutes. Since there is burned-in timecode, I check if the timecode holds from beginning to end. If there is a drop I have to start a new recording; capturing without device control using Media Express latest version.
    http://www.postproduction.be
    Dirk Dejonghe replied 15 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
