Activity Forums Adobe After Effects Missing frames at end of AE sequence
  • Missing frames at end of AE sequence
    Posted by Corrie Parks on December 17, 2016 at 1:41 am
    There is a weird thing happening with importing a frame sequence into AE. The last few seconds of a sequence look like they import but appear as a frozen or black frame during playback.
    I’ve made a screen capture describing the problem here:
    https://youtu.be/XVMMZ6Fzkjs
    I have checked the image sequence numbers, there are no gaps, plus in the project window it appears the number sequence goes from beginning to end.
    The sequence was exported from Lightroom at 7360×4912 and put into a 4K composition in AE. I tried importing a 1920×1080 proxy of the same sequence and it stalled at the same spot.
    Both the full res sequence and the proxy import fully into Premiere. I can import the Premiere project and the footage seems to show up (though I have only tested this with the proxy)
    Cleared and cleaned the AE cache with no effect.
    Working on Windows 10.
    Plenty of HD space
    Any suggestions on what to try next would be welcome. I’m baffled. Thanks!
    Corrie Parks replied 9 years, 9 months ago 1 Member · 1 Reply
  • Corrie Parks
    December 17, 2016 at 2:01 am
    Should have checked the adobe AE help forums first. Apparently others have encountered this and it’s a bug with the new JPEGImporter.
    For anyone needing a work around until the bug is fixed, this worked for me
    https://forums.adobe.com/message/9124077#9124077
