Activity Forums DaVinci Resolve Missing frames
  • Missing frames
    Posted by Ingi Fiev on April 27, 2018 at 5:18 pm
    Hello,
    The answer is probably very simple.
    We have footage in dng image sequences with missing frames, it would be okay but Da Vinci won’t import the whole shot as ONE sequence, by ignoring the missing frames (by replacing them with black frames for example), and instead it imports up to hundreds of sequences for a single shot (some shots are 2500 frames long with up to 150 missing frames), and that is very problematic for our workflow, any way to import it as a single sequence?
    Thank you!
    Ingi Fiev replied 8 years, 4 months ago 2 Members · 2 Replies
  • Glenn Sakatch
    April 28, 2018 at 2:47 am
    You are probably not fooling Resolve by creating a black frame and calling it .dng?
    you might want to instead copy the previous frame, and rename it to the bad frame. You would at some point have to go through and spot those bad frames and figure out if they need a fix.
    Glenn
  • Ingi Fiev
    April 29, 2018 at 1:20 pm
    I accidently reported your response Glenn, unable to see it anymore
