Activity › Forums › Apple Motion › Missing filters in Motion
  • Missing filters in Motion
    Posted by Paul Soender on January 15, 2007 at 11:03 am
    Hi. I’ve just installed Motion on my new mac. I’ve worked with motion earlier, at another workplace. Now when i start motion, and look at the filters, it’s like there’s missing alot ? I only have a few filters, and need some of the ones i’m used to. Anybody know how to solve this ? Do i have to set it up to showing the full potential, or install an extra packace/update ?
    thanx in advance
    – Paul
    Paul Soender replied 19 years, 8 months ago 2 Members · 2 Replies
  • Gabriele De simone
    January 19, 2007 at 3:58 pm
    Though I can’t offer a solution, your problem can only have two causes:
    – your other workplace had a lot of third-party effects installed
    – your installation is screwed up 🙂 What system are you on (esp. Intel vs PowerPC) and what version of Motion are you using?
    In general, 3rd Party Plug-in that use the older AE SDK support should not be used on Intel Macs at all. Some companies have found ways to make them work on Intel, but it’s a somewhat nasty hack. Things are a bit better on the PowerPC side. The path to these AE plug-ins is specified via one of Motion’s preferences (the last option in the first preference tab).
    Newer plug-ins that use the FxPlug SDK (Apple-brewed), will not show up under the “3rd Party Effects” category. They will show up in the regular categories along with the built-in filters, which can be confusing at first. You can check for all FxPlug plug-ins installed on your system by looking into these directories:
    /Library/Plug-ins/FxPlug
    and
  • Paul Soender
    January 19, 2007 at 5:41 pm
    I dont have any 3rd party filters installed. But with a clean install of motion i only have 39 filters. I’m missing gaussian blur, gloom, dazzle just to name a few.
    I have a brand new mac pro, with motion 2.1.2 installed…
