Activity Forums Adobe After Effects Missing files
  • Missing files
    Posted by Sara Jean on December 5, 2007 at 7:50 pm
    Hi!
    I had some Photoshop files go missing after transferring them to my external hard drive. Is there an easy way to reconnect media? I tried reloading footage but it didn’t do anything.
    Sara Jean
    John Spencer replied 18 years, 9 months ago 2 Members · 1 Reply
  • John Spencer
    December 7, 2007 at 4:29 pm
    You need to right click each layer in the Photoshop Doc in After Effects then click on Replace Footage; click on File; then locate your document click ok. It “should” reconnect for you. If not then you might have renamed the file or something. Let me know if that works for you. If all else fails then just reimport the document and replace the layers manually.
    -Spence.
