Activity Forums Apple Final Cut Pro Legacy MIssing Files
  • Posted by Randy Rohde on May 9, 2005 at 7:29 pm
    Going nuts here… I creat a sequence complicated has clips i did a lot to and exported as a QT and imported into the bin and on the timeline and all is well. The next day I open the project and warning file missing (always a rendered file “open-fin 00005f” or somethinf) so i didn’t create the file I didn’t delete the file??? Any thoughts. Also in the same vein.. i will create a complicated clip with lots of stuff motion blur speed scale etc…. and I export the clip as a QT and then import that clip into a bin and on the timeline 10 minutes go by and the clip on the time line turns white and won’t play. I try pulling from the bin into the slug and nothing is there… then a red line across the clip mane in the bin appears (Where are all the clips going)
    Todd Beabout replied 21 years, 4 months ago 2 Members · 1 Reply
  • Todd Beabout
    May 9, 2005 at 7:36 pm
    When you export your QT file, check the box that says “Make Movie Self-contained”. You were exporting QT reference movies and something is getting messed up in your workflow.
    -Todd Beabout
    Vazda Studios
