Activity Forums Apple Final Cut Pro Missing Event
  • Missing Event
    Posted by Eric Klassen on July 18, 2013 at 8:45 pm
    I just went through the process of Moving several Events from one computer onto an external. I used Command+Drag/Drop into the external icon within the FCP interface. To save storage space on the external, I started deleting render files from some of the projects before moving the projects over, but then I noticed the timelines going red and saying “Missing Event” (see attached) so I moved the Events back onto the computer to see if that would synch everything back up…no dice. What’s going on?
    I understand how to re-link Project files, but how do I re-link a Project to it’s Event?
    Any help is most appreciated.
    Eric
    Jeremy Garchow replied 13 years, 2 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    July 18, 2013 at 9:47 pm
    Select the Project in the Project Browser.
    In the inspector under the Properties tab, choose Modify Event References.
    Point it at the hard drive the Event is now stored.
    Jeremy
