Activity › Forums › Adobe Encore DVD › Missing effects and title frame, on 3 of 12 sequences, possible solutions?
  • Missing effects and title frame, on 3 of 12 sequences, possible solutions?
    Posted by Rob Manning on November 27, 2012 at 9:05 pm
    Hi Adobists,
    I checked the history and Adobe’s site generally but nada.
    I’ve built 12 frame grabs as a leader to 12 songs in order to show up in the menu buttons. Same background, different text in title overlay, frame grab saved as image.
    3 of the 12 songs do not import correctly with color corrections and the leader still (frame grab) is missing.
    I tried rebuilding the entire Encore project from scratch, with the same result.
    Also, if I start a new project using one of the suspect sequences the files show up intact but subsequent adds of the other two performances load with the missing results. The other 9 songs are fine BTW.
    So, the files work if loaded from the PP drop down under (open with dynamic link) but only on an single timeline, initial new project.
    I tried eliminating the frame grabs and rebuilt the slides with the same results.
    Anyone have a suggestion?
    I’m all ears, with a deadline.
    1) Is it possible to load the stills in Encore, and add it ahead of the timelines (4 seconds long)? I suppose It’s possible to add the button with the still and pick whip from there to the sequence but as noted the content issues are unresolved.
    2) Is there a way to copy and paste from one Encore project to another without using PP?
    3) I’m using a title template from the first song, perhaps I should start fresh, as it’s obvious DL is seeing an unfinished timeline and perhaps the template has been corrupted?
    Any help is welcomed, I will cruise the tutorial videos as well once again.
    Rob
    Rob Manning replied 13 years, 10 months ago 1 Member · 1 Reply
  • Rob Manning
    November 30, 2012 at 9:40 am
    Bottom line, do not rely on Dynamic Link, export to DVD/BluRay format, and load Encore from these rendered files.
