Activity Forums Media 100 missing driver, need help..Flo?
  • missing driver, need help..Flo?
    Posted by Cj on September 28, 2005 at 6:40 pm
    Am running M100 8.2.2 on G5 with expansion chassis. All was well until I JUST installed FCP HD 4.5 and when I went to open M100 I got the following message: Could not start the application because the Media 100 driver (Media_100_Vincent.kext) failed to load.
    I reinstalled M100 and got the same message again. Where would I find this driver to install?
    Thank you!
    Cj replied 20 years, 11 months ago 2 Members · 3 Replies
  • Floh Peters
    September 28, 2005 at 6:45 pm
    The kext should be in System->Library->Extensions. But this sounds like you have some sort of hardware problem. Have you tried to run the Media 100 hardware test? Are your connections to the expansion chassis okay? Power on on the expansion chassis?
  • Cj
    September 28, 2005 at 6:48 pm
    Whew…..my mistake – thank goodness. When I installed FCP, I did not have the expansion chassis turned on. I went to open M100 and forgot the chassis was off.
    All is okay again.
  • Cj
    September 28, 2005 at 6:49 pm
    You are truly amazing……I hope you know how much we all appreciate you! Thank you Floh!!!!
