Activity Forums Adobe After Effects missing data file
  • missing data file
    Posted by Beak on September 29, 2005 at 12:20 am
    HELP!
    I’ve been working all day on a bunch of complex comps.
    When I go to save and shut down, AE won’t save. The info window reads
    saving… 11%.
    So I saved a copy and then closed AE.
    Now when I attempt to open the “saved as” version I get an error message.
    “missing data file”
    I’ve repaired permissions and it still won’t open.
    Am I screwed and if so what happened so I don’t do it again?
    AE 6.5
    G5 dual 2G
    thanks
    beak
    Steve Roberts replied 20 years, 12 months ago 4 Members · 5 Replies
  • Dan Ebberts
    September 29, 2005 at 4:06 am
    Have you tried importing the damaged project into a new project? Sometimes that works.
    Dan
  • Steve Roberts
    September 29, 2005 at 4:12 am
    … and for God’s sake, save the project under a new name every hour, not at the end of the day. Use AE 6.5’s built-in “incremental save” feature.
    Then … only keep the most recent day’s set of AEPs if you like, or maybe keep one from each day’s work before that.
    Steve
  • Beak
    September 29, 2005 at 1:33 pm
    I’ve tried importing the project and I get the same error message.
    Next I’m going to try opening project on a different box all together.
    Beak
  • Peter O’connell
    September 30, 2005 at 12:58 am
    This advice is a bit too late but from now on as Steve recommended use incremental save.
    Shift Option Command S
    then if a file gets corrupted you can go back to the previous incremental save. Some days I’ll get up to version 150 of a certain comp. AE project files are tiny so it is well worth it
    Pete
  • Steve Roberts
    September 30, 2005 at 2:01 am
    To the masses:
    Your time between incremental saves should be equal to the amount of work you’re willing to re-do. A day? An hour?
    If you save incrementally once a day, be prepared to re-do a day’s work if your project goes south. If you don’t save incrementally at all, be prepared to re-do all your work from scratch.
    And if you’re short on time, you might miss the deadline and blow the job.
    ’nuff said. 🙂
    Steve
