Activity Forums Adobe After Effects Missing Cycore plugs in CS4
  • Missing Cycore plugs in CS4
    Posted by Rob Hindley on February 13, 2009 at 10:53 am
    OK. So I’ve installed my legitimate paid version of Adobe CS4 MAster Collection.
    But upon opening AE I see no CC plugs in the Effects menu.
    I thought these automatically load with the AE installation.
    Somebody please advise as I have depended on these great plugs for my commercial work. Thanks.
    Rob Hindley replied 17 years, 7 months ago 2 Members · 2 Replies
  • Steve Renard
    February 13, 2009 at 5:30 pm
    Not sure if this is your problem, but when I installed CS3 the first time I had to go back and install the CC plugins separately. I can’t recall what the process was, but try running the installer again and see if there’s an option to install the plugins separately. As I’m thinking about it, too, there might also have been a separate installer for the CC plugins, or I might have simply copied them from the install disc into the AE CS4 plugins folder.
    I do remember having that problem with the CS3 install though, and got it sorted out eventually, so hopefully you will have the same luck!
    Steve
  • Rob Hindley
    February 14, 2009 at 3:59 am
    Success!
    CC plugs are only available once the serial number is used rather than the trial version.
