Activity Forums Apple Final Cut Pro Legacy Missing Codec?
  • Posted by Chris Jilka on January 15, 2007 at 3:46 pm
    Hello all… my OS recently crashed and I had to reinstall it… thankfully an archive and install worked. Everything came back up in ok in Final Cut, except for some reason is doesn’t recognize the HDV firewire codec that I used to capture some footage. I’m sure I picked the HDV 1080i codec… the weird thing is that Easy Setup is there… My error message reads: “Codec not found. You may be using a compression type without the corresponding hardware card.”
    Chris Jilka replied 19 years, 8 months ago 2 Members · 2 Replies
  • 13 Create COW Profile Image
    13
    January 15, 2007 at 5:09 pm
    reinstall FCP
  • Chris Jilka
    January 15, 2007 at 5:55 pm
    Thanks! That worked.
