Activity › Forums › Apple Motion › missing bezier points
Posted by Hmvideo on March 21, 2007 at 9:41 pmI drew a path. Now I can’t see or edit the bezier points. I right click and choose ‘edit points’ … nothing. Trashed prefs … same thing. Drew a rectangle as a test … same thing. Can anyone tell me how to get the bezier points on a shape path to reappear?
Many thanks!
Rick Dervisevic replied 17 years, 10 months ago 3 Members · 4 Replies -
Tony! Hulette
March 26, 2007 at 9:58 pmAre you sure you are not selecting the B-Spine tool? It’s a wonderful tool for drawing a path quickly, but it does not give you bezier handles (not necessarily a bad thing). If you click and hold on the path tool you’ll see that there are two to choose from. One for Bezier and one for B-spline. A pop-up message will display in a couple seconds if you hover over the tool, letting you know which one is which.
Tony!
Hmvideo
March 31, 2007 at 9:38 pmThanks Tony. I’m familiar with B-splines, but that’s not the case here. I simply can’t get bezier points to appear.
I open MOT, click on the Bezier tool, draw a path, and I can edit the points. If I go back to the arrow tool the path gets stroked. Then if I want to edit the points, typically I’d right click the path and select ‘edit points.’ The tool switches to the ‘adjust control points tool’, but no point appear. If I uncheck ‘outline’ in the inspector for the shape, the path disappears completely. Also, I can’t uncheck ‘edit points’ if I right click the path again. It just stays checked no matter how many times I try to uncheck it.
Annoying, and I can’t finish this particular bit not..
Hmvideo
May 15, 2007 at 7:35 pmOK, the answer is … be sure ‘show overlays’ in the canvas’ view menu is checked. Doh!
All is now well …
Rick Dervisevic
November 14, 2008 at 12:11 amthanks for the answer, I had the same problem… doh(squared)2!
