Activity Forums Boris FX Missing BCC Mosaic with CS5
  • Missing BCC Mosaic with CS5
    Posted by Tim Stonesifer on May 24, 2011 at 8:19 pm
    Somewhere along the way I picked up BCC Mosaic & Tritone for CS4. It was probably a freebie from somewhere. However, I’m not able to get them to work on CS5, or find versions of them for CS5. Anybody know where I can get them? Thanks.
    Peter Mcauley replied 15 years, 4 months ago 2 Members · 1 Reply
  • Peter Mcauley
    May 25, 2011 at 1:30 pm
    Hi Tim,
    Adobe CS 5 is a 64 bit application – Adobe CS 4 is a 32 bit application. The freebie BCC Mosaic and Tritone filters that you were using were designed to be used in a 32 bit application and cannot be used in a 64 bit application. There is no way to get them to work.
    We recoded the filters in the BCC package so that they are 64 bit with the BCC 7 release, in an effort to make them compatible with 64 bit applications, such as CS5.
    The only way for you to use these filters in CS 5 is to use the 64 bit versions, which are available as part of the BCC 7 filter package. You can download a free demo version here:
    borisfx.com/downloads
    Cheers,
    Peter.
