Activity › Forums › Apple Final Cut Pro Legacy › missing A/V device after upgrading to tiger
  • missing A/V device after upgrading to tiger
    Posted by Alex on June 7, 2005 at 7:44 pm
    i just updated to tiger 14.1, when i launch fcp 4.5 external a/v device is missing.
    it works fine in imovie. i trashed all pref.
    i tried it on a 10.3 os and no problem. any suggestions? thanks!
    Robert Gillmer replied 21 years, 3 months ago 4 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    June 7, 2005 at 8:04 pm
    Did you re-install FCP after updating to Tiger? You really should re-install all pro-apps after an OS upgrade.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Alex
    June 7, 2005 at 8:09 pm
    thanks for the reply…
    what is the best way to “uninstall” fcp and the rest of the apps? i usually search for the folders and maually delete. is there a better way?
    thanks
  • Alex
    June 7, 2005 at 8:10 pm
    thanks
  • Walter Biscardi
    June 7, 2005 at 8:15 pm
    Go to Apple’s Site and in the Support section search for “Uninstall Final Cut Pro 4” There’s a whole article on how to do it.
  • Alex
    June 7, 2005 at 10:01 pm
    okay…just completed an entire uninstall and re-install of fcp 4.5 as instructed by the apple web site.
    with all me fingers crossed i open fcp and wula…i have the same problem:(
    “unable to locate Appple FireWire NTSC (720 x 480)”
    dumb question, but do i need to download quicktimePRO??? can this be the problem??
  • Walter Biscardi
    June 8, 2005 at 10:03 am
    [Alex] “dumb question, but do i need to download quicktimePRO??? can this be the problem??”
    Nope. Quicktime Pro has nothing to do with any functionality within FCP.
    could be your cable is bad, or the Firewire port on your device or the Mac went bad. Be sure to never connect or disconnect anything from the Mac when that device is powered up.
  • Alex
    June 8, 2005 at 4:45 pm
    The odd part is that i can capture fine with imovie…
    In FCP 4.5 I have machine control in my capture window but no audio or video. It shows as “missing apple ntsc…” I went ahead and installed quicktimePro as well.
    Very fustrating!!! Any thoughts??
  • Robert Gillmer
    June 9, 2005 at 12:32 am
    Sorry that you haven’t gotten an answer to your problem. I’ve got the same one!!! I’m using a Sony DSR-11. What are you using?
  • Robert Gillmer
    June 9, 2005 at 2:17 pm
    Son of a bitch, I thought Windows was some crazy shit, but I’m never gonna figure out this Mac OS. I had the same problem with FCP 4.5 HD after upgrading to Tiger and QT 7. I’m running a dual 1.8 G5 with no additional cards, just for the record. Well, after searching all over for an answer, I found one on the Apple FCP forum. I downloaded and installed Quick Time 7 and viola, I have video!? Now, if someone can explain to me how Quick Time, which isn’t running, could prevent FCP from seeing my video deck (a Sony DSR-11, by the way), and yet allow Imovie to use the deck, and THEN by reinstalling THE SAME PROGRAM, everything suddenly starts to work, I probably wouldn’t be able to understand the answer anyway!!!!
  • Craig Burnett
    June 9, 2005 at 5:32 pm
    I had pretty much the exact same problems…FCP 5 was seeing my drives, but not the camera plugged into the same FireWire hub.
    Downloaded QT7, re-installed it, and voila…it works!
    Wonder if the QT7 included in the FCP Studio package is buggy or something.
    In any case, the Cow wins another one for the little guy!
    -Craig Burnett
    craigieb@aol.com
    http://www.craigburnett.com
