Activity › Forums › Apple Final Cut Pro Legacy › missing audio waveforms
  • Walter Biscardi
    May 16, 2006 at 11:35 am
    Depending on your zoom level on the timeline and the length of teh clips, waveforms may not show up on some clips until you zoom very far in. Shorter clips will sometimes not show the waveform depending on the zoom level.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Henryfelt
    May 16, 2006 at 11:38 am
    Thanks Walter, but that doesn’t seem to be the problem. It’s more like a bug.
  • Walter Biscardi
    May 16, 2006 at 11:40 am
    Is there actually audio on the clips where the waveforms are missing?
    You can trash your Thumbnails and Waveform cache. Definitely no waveforum bug here running FCP 5.0 and 5.1 on multiple systems.
  • Henryfelt
    May 16, 2006 at 12:28 pm
    oh yes, I can hear it loud and clear
  • Henryfelt
    May 16, 2006 at 12:38 pm
    I also have x’s in the timeline where the waveforms should be
  • Debe
    May 16, 2006 at 2:15 pm
    Does making the tracks a little taller help?
    debe
  • Frank Nolan
    May 16, 2006 at 6:44 pm
    Did you try trashing the waveform and thumbnail cache as Walter suggested?
  • Henryfelt
    May 16, 2006 at 10:45 pm
    Yes i did, but still I get x’s. Not on all clips, but almost all regardless of their size.
