Activity › Forums › Adobe Premiere Pro › Missing audio waveforms in nested sequences, CC
Posted by Brian Sarfatty on November 11, 2013 at 7:45 pmIn previous versions I had to “render audio” to get the waveform to show up in Nested Sequences. In CC, I am getting NO WAVEFORMS in Nested Sequences, and Render Audio doesn’t work.
Now, supposedly, in the latest version, you no longer need to Render Audio to get audio waveforms?? But, umm, I have no waveforms.
Have tried everything – playing with creating multi-camera sequences, deleting peak audio generation and turning back on again. NOTHING works.
Any suggestions? Anyone else having this problem? Is this a bug?
Edward Boyce replied 9 years, 8 months ago 9 Members · 13 Replies -
Miguel De sá
November 13, 2013 at 8:18 amI have the same problem. The thing is that in my personal computer (windows) i don`t have this problem. Only on my the Mac…
Some Help Please! Any one?
Brian Sarfatty
November 13, 2013 at 2:50 pmSO, when I take two clips and right-click and select “Make Multi-Camera Sequence”, the resulting sequence gives me waveforms.
HOWEVER, I have gone through and manually synched many many clips into one timeline. In previous versions I could just nest said timeline into another, click multi-cam>Enable, and viola, I have multicam sequence. Now, while this still works, this workflow produces an empty waveform.
I have tried first creating a TRUE multicam sequence from clips using “Make Multi-Camera Sequence” and then replacing the content with my pre-syched sequence of several clips. Interestingly, when I do this, the waveforms disappear.
Brian Sarfatty
November 13, 2013 at 4:45 pmSo, I decided to roll back to Premiere CC 7.0, and suddenly my waveforms are there and I can render audio as usual. The issue seems to be specific to CC 7.1 which came out 10/31/13.
So if you use multicam, and like audio waveforms, DO NOT upgrade. Also, 7.1 has crashed a lot more frequently than 7.0.
To Roll back, I just restored the Adobe Premiere Pro CC application folder using Time Machine.
If you don’t have a Time Machine backup, here’s instructions to download the old version:
https://forums.adobe.com/message/5827476I now have waveforms again, hallelujah!
Brian Sarfatty
December 9, 2013 at 5:12 pmAnd now I re-upgraded to deal with a different problem, that was fixed in 7.1.
Brian Sarfatty
December 18, 2013 at 4:52 pmAlright, update!!!! 7.2 resolved this problems, and lets me Render Audio as usual, and I now have waveforms for Multicam Audio.
Matt Orfalea
April 18, 2014 at 5:23 pmHow bout for nested sequences?
That would be nice if I could figure that out.
Thanks in advance!
Matt
https://www.youtube.com/orf -
Jayson Rahmlow
April 22, 2014 at 2:29 amJust figured this out. The way to get waveforms to show up in Adobe Premiere CC 7.2.2 atleast is to make sure none of the audio clips inside the nest have any effects on them. Soon as you strip all the FX off of the audio clips in the nest you’ll see your waveforms again when you drop the nested sequence on a timeline. This was driving me batty but just dumb lucked into figuring it out today.
Cheers,
Jayson -
Daniel Mcdonald
December 16, 2015 at 9:22 pmTHE ANSWER (for me at least): Mute all audio tracks in the nested sequence that you don’t to use. Only leave unmuted the audio you wish to use. But do NOT solo anything in the nest! Soloing audio in nested sequences prohibits waveforms from showing in Premiere, for some reason – at least I see this happening everyday on our computers at work.
Daniel McDonald
M.F.A. Chapman University – Film Editing
http://www.danielmcdonald.net -
Brian Sarfatty
December 16, 2015 at 9:29 pmTHANK YOU. We encountered this the other day, been searching for a solution for years.
Randy Cates
February 16, 2016 at 3:45 pmI had some seqs. showing waves and others not. Restarting the app solved it for me.
R.Cates
Randy Cates
Video Production/Motion Graphics
