Activity Forums Adobe Premiere Pro missing audio on export
  • Jeff Bonano
    November 9, 2009 at 9:54 pm
    It could be a couple things, so start by double checking the obvious:
    In your time line check to make sure everyone of the audio tracks are turned on. If that looks fine, I would also check your audio levels to see if they are turned down. Check also to make sure you are rendering it with the proper audio setting before you process it. Give another shout out if that doesn’t fix it.
    Jeff Bonano
    http://www.bonanoproductions.com
    “I want to have a cool quote at the bottom of my signature, just like everyone else on the cow forum!” -Jeff Bonano
  • Sterling Youngman
    November 9, 2009 at 9:59 pm
    I don’t know why this would have anything to do with it, but I deleted all rendered files in the work area, and then when I exported, I got the audio.
    -Sterling
