Activity Forums Apple Final Cut Pro Legacy Missing Audio on capture
  • Missing Audio on capture
    Posted by Pe1234 on April 6, 2006 at 2:38 am
    Hello,
    I’m capturing several clips via FireW from my Panasonic XL-100 to my laptop with FCP-HD. However FCP seems to only log V1 and A1 BUT NOT A2. So when I go to capture A2 is missing.
    First, I have not changed anything since I last used the set-up, however
    I have tried several things to resolved the isssue, nothing has work:
    1. Swith tapes – no change
    2. Checked capture settings tried Mono-Mix and CH-1+Ch2 – no change
    3. Checked Audio/Video settng (set to cpature 2 chs – no change
    4. Changed Firewire, just in case – no change
    5. Closed and re-opned FCP – no change
    6. Check all camera settings – no changed
    7. Changed Speakers to ON while cpaturing, I can hear both channels ut ONLY ONE is capture once is done
    **INTERESTING facts:
    1.When this first happened and I digitized all clips, I accidently redigited an older clip (HOUSE_SHOT) already in the bin, it just used the timecodes and re-did it from the current tape… IS THE ONLY CLIPPED THAT LOGGED AND CAPTURE BOTH A1 and A2 ???
    2. When I CTRL-click (the clip HOUSE_SHOT) > item properties> Loggin Info > It shows it logged both A1 and A2 but when I do the same for the other clips the logging info only show A1 ??
    Hope I have been able to explain…. you help is greatly appreciated.
    Creative Animal jan replied 20 years, 4 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    April 6, 2006 at 3:07 am
    The first thing to always try is to Quit FCP, Restart the Mac, Open your FCP project and try again.
    Next:
    THE FOLLOWING COMES FROM THE KEN STONE WEBSITE:
    “Over 5,000 years ago Confucius wrote: ‘If you are toiling away, you have changed nothing and FCP heads South on you, [starts behaving in strange ways] then it is time to trash your FCP Preferences.’ ”
    Click the following link for instructions.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    A great way to do this is to use “FCP Rescue” a free Apple Script that will Trash the Preferences for you (and restore nearly all of your user settings afterward).
    There are versions for FCP (Pro) & FCE (Express) and a new one for FCP 5.
    Download these free Apple Scripts at
    https://fcprescue.andersholck.com/
    or
    https://pistolerapost2.com/fcprescue/
    This is one FCP tip that has helped in solving hundreds of “odd” problems.
  • Creative Animal jan
    April 7, 2006 at 9:30 pm
    Most likely, you have to check the a2 box in the following menu: log&capture (command8) — capture settings — audio window — check both a1 and a2 and enable preview box
