Activity › Forums › AJA Video Systems › Missing Audio in Edit to Tape – AJA PLS HELP
  • Missing Audio in Edit to Tape – AJA PLS HELP
    Posted by Morten on March 2, 2006 at 8:27 pm
    Problem editing a program to Digibeta VTR w. SDI/embedded Audio from FCP/Kona 2.
    The audio plays fine during ETT, and even displays on the VTRs meters – but only records some times (though I can hear it when scrubbing the tape). Picture comes through fine every time.
    We diden’t have this problem 2 weeks ago – and have only performed upgrade of Soundtrack (to latest version) and installed After Effects 7. Suspected it to be a tape control error, and tried to control deck from USB twinspan adapter – but problem remained.
    Using FCP 5.04 – Kona 2 v 2.1 – Tiger OS 10.4.5
    – No Parking Production –
    Finalcut Studio, Dual G5, Kona 2, X-Raid
    Bob Zelin replied 20 years, 6 months ago 2 Members · 3 Replies
  • Bob Zelin
    March 4, 2006 at 6:05 pm
    you say that when you ETT, it even displays on the VTR meters, correct ?
    But when you play back the VTR, you get no audio – correct ?
    ITS YOUR VTR ! Do a manual insert edit test on your VTR, not using FCP. Just send in bars and tone from the FCP system to the VTR, and do a manual
    insert edit – if you get no audio (but see the meters moving in E/E and confidence mode) – it’s your VTR.
    Bob Zelin
  • Morten
    March 5, 2006 at 9:38 pm
    The VTR is rented from an AVID production studio – and they use it every day without problems.
    This is why I suspect it to be a Kona2 or/and FCP related problem. After all it is the NLE that tells the VTR what and where to insert. The funny thing is that the problem is not consistent – sometimes the audio does get recoreded properly…
  • Bob Zelin
    March 6, 2006 at 12:45 am
    rental VTR’s get very beat up all the time. PLEASE simply put up bars and tone from your FCP system – output into your VTR, and put the VTR manually into an insert edit from the front control panel. It’s easy. You will tell in 2 seconds if the VTR has a problem.
    I had a similar problem to you once, and it was due to an unstable black reference between the K-Box and a Digi Beta VTR. Make sure that both machines have a common black reference, and that the control tab is checked to Ext Ref, and not video in.
    bob zelin
