Activity › Forums › Apple Final Cut Pro Legacy › (missing) apple firewire ntsc (720×480)
  • (missing) apple firewire ntsc (720×480)
    Posted by Eric Anderson437 on May 30, 2007 at 12:49 am
    I upgraded to 10.3.9 and HD FCP. Since then I can’t connect with my dsr 20 deck. I’ve trashed fcp prefs and qt prefs. Pop up says (missing) apple firewire ntsc (720×480). Are there drivers or some kind of up grade I need to do with 10.3.9 to get it to work with HD FCP? Checked everything I can think of and no dice! Anybody have any other ideas??????Thanks, Eric
    Jerry Hofmann replied 19 years, 4 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    May 30, 2007 at 2:36 pm
    Reinstall QuickTime 6 if you’re running QT 7… it doesn’t play well with FCP HD on Panther.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
