Activity Forums Apple Final Cut Pro Legacy Miss Matching Sequence Settings In Same Project
  • Miss Matching Sequence Settings In Same Project
    Posted by Mark Fanjoy on March 21, 2009 at 9:33 pm
    Hi guys. Quick question. My entire project is pre set for Apple Pro Res 422 (HQ), 16 x 9 24p. I have a doctor testimonial to edit shot in 4×3 SD. When I create a new Sequence for the cut down FCP prompts me to change the Sequence settings to match the video. Do I say Okay to this without disturbing the settings in the other sequences, or does FCP make this a universal project change?
    Related to this, can I later insert the sequence block into the main show timeline with the same question?
    Thank you in advance for your support.
    Wherever I am…I’m lost!
    Mark Fanjoy replied 17 years, 5 months ago 2 Members · 2 Replies
  • Walter Biscardi
    March 22, 2009 at 12:43 am
    [Mark Fanjoy] “Do I say Okay to this without disturbing the settings in the other sequences, or does FCP make this a universal project change? “
    It only affects that one Sequence.
    [Mark Fanjoy] “Related to this, can I later insert the sequence block into the main show timeline with the same question? “
    No. The Sequence will not change if you insert a nest into something that has already started editing.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Mark Fanjoy
    March 22, 2009 at 12:49 am
    I love this site! I sit here and get stuck on something, I plug in a question, you guys jump all over it, and I’m once again off to the races on my project!
    Thank you all!!
