Activity Forums Apple Final Cut Pro Legacy ‘Mirror on Desktop’ causing dropped frames
  • ‘Mirror on Desktop’ causing dropped frames
    Posted by Tom Vaughan-mountford on December 21, 2011 at 9:29 am
    Hello – I’m trying to sort an issue for one of my editors.
    We’re using FCP 7.0.3 and are experiencing a maddening continual dropping of frames on playback (even on single-stream sequences) and have to throttle FCP back to ‘Medium’ video quality in order to play projects to clients – we use XDCAM-EX so we aren’t exacly pulling massive bitrates from disk (see specs). We are deriving the output for our client screen as 1080i coming from an installed Blackmagic Intensity (HDMI) card, and I updated the drivers for this to Digital Desktop 9.0 but this didn’t provide a solution.
    The ONLY workaround I’ve found so far is to turn off ‘Mirror on Desktop’ in FCP’s Audio/Video Settings – this gives 1080i playback to the client screen without dropping frames, but naturally disabling the Canvas window makes it very difficult to edit! The converse is also true, if I turn off External Video playback the video in the Canvas window also becomes free of dropped frames – it just seems unable to provide an output to both without struggling to maintain the required framerate.
    Specs:
    • MacPro 2.66GHz Quad-Core Xeon
    • 3GB RAM
    • OS X 10.6.8
    • 4TB internal striped RAID, 2x 7200RPM SATA – benchmarked at 274MB/s read (with 3TB available space)
    • Blackmagic Intensity – running Digital Desktop 9.0
    • FCP 7.0.3
    All help most gratefully received!
    Cheers,
    Tom
    Bret Williams replied 14 years, 9 months ago 2 Members · 1 Reply
  • Bret Williams
    December 21, 2011 at 5:34 pm
    Do you have video scopes playback on? The timeline is fully rendered?
