Activity Forums Adobe After Effects Expressions Mir scroll Y texture slipping – Is there an offset expression to prevent this?
  • Mir scroll Y texture slipping – Is there an offset expression to prevent this?
    Posted by Lori Lin on August 25, 2017 at 3:39 pm
    Hi all!
    I think there must be a way to keep the texture from slipping and jerking when you use the Y scroll in Mir. Math and expressions are totally not my strong point, so I’m scratching my head here!
    Say my texture is 2500×1700 (x,y) and my Mir scroll Y value is time*100.
    My comp looks best if I set the texture scale settings in MIr to scale x = 8 and scale y = 5.
    I have tried offsetting the texture in a precomp with an expression I found here (I believe it was Dan’s)
    value + [0,time*100]
    But that’s not doing the trick. Any pointers about how to set up an offset expression that will work? I hope so, because the results would be very cool!
    Cheers,
    Lori
    Lori Lin replied 9 years ago 1 Member · 0 Replies
  • 0 Replies
