Minute:Second Timer in Vegas
Posted by Nick Gipson on April 4, 2015 at 10:12 pmI want to add a clock in the bottom right corner of my video but the official Timecode effect doesn’t offer the format I want, I just want Minutes and Seconds shown, not the hours or the MicroSeconds (or whatever they are) I want to use it for short videos so I feel I’m going to have to make my own frame by frame.
I don’t really want to do that though, so what other options do I have?
Aleksey Tarasov replied 11 years, 5 months ago 5 Members · 10 Replies -
Nick Gipson
April 4, 2015 at 11:47 pmI’m well aware of the options available “Seconds” only shows just that, I’m wanting “Minutes:Seconds”
Norman Black
April 5, 2015 at 3:10 amYou can mask off the parts you do not want when using the Time preset. Mask off hour and fractional seconds.
This will not work if your minutes count is greater than 59.
Graham Bernard
April 5, 2015 at 3:55 am[Norman Black] “This will not work if your minutes count is greater than 59.”
Norman is correct. However, as you say Nick :
[Nick Gipson] “I want to use it for short videos“
How “short” is short? If it is up to 59 minutes and 59 seconds you’ve got a solution, after that the minute Counter resets itself to ZERO. If this is good for you, then this is far FAR better than making a minute counter! – . . . .
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Graham Bernard
April 5, 2015 at 4:09 am[Graham Bernard] “If it is up to 59 minutes and 59 seconds you’ve got a solution, after that the minute Counter resets itself to ZERO”
Actually, you COULD then use that facility to create a SINGLE text event for each of the subsequent “10” minute sets and just allow the underneath 0,1,2,3,4,5,6,7,8,9 to tick over. Yeah, I could foresee an option to allow to carry beyond 59:59 – at least up and until the “100” minute marker. Do you see that?
Grazie
Nick Gipson
April 5, 2015 at 8:31 am -
Graham Bernard
April 5, 2015 at 10:08 am[Nick Gipson] “I’m looking to use it in 3 minute long reviews maximum”
Nick, what is your outcome to all this? Is it purely for timecoding allowing a 3rd party to make notes?
Grazie
John Rofrano
April 5, 2015 at 11:06 amNick, I’m trying to follow this thread and you’ve been given the solution several times and you’re still acting like you don’t know how to do this so let be reiterate what others have already said but with more detail:
- Drop Sony Timecode onto your timeline event
- Set the Timecode format to Time & Frames
- Click the Pan/Crop tool on the event to open it
- Check the Mask checkbox to enable masking
- Create a small mask in the corner around just the minutes and second
- In the Mask Properties set Apply to FX to Yes
- Adjust the mask until only the minutes and seconds are displayed
That’s it! Feel free to ask questions but this is the solution that others have been suggesting to you.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Aleksey Tarasov
April 5, 2015 at 12:10 pmYou can use Vegasaur free trial and its Text Wizard to generate this counter…
Here is an example project: timer.veg.zip
