Activity › Forums › AJA Video Systems › minimum system for LH card
Posted by Rick Lavon on December 26, 2005 at 7:48 pmthe AJA website says it should be the 2.5 Dual Ghz G5 for digitizing uncompressed SD. Is that the case? or can a Dual 2.0 Ghz G5 handle this as well?…
Walter Biscardi replied 20 years, 9 months ago 3 Members · 5 Replies -
Walter Biscardi
December 27, 2005 at 1:13 pm[Rick Lavon] “the AJA website says it should be the 2.5 Dual Ghz G5 for digitizing uncompressed SD. Is that the case? or can a Dual 2.0 Ghz G5 handle this as well?…”
They give the same minimum specs on the Kona 2 as well, but we’re only running Dual 2.0’s in both of our suites and they handle Uncompressed SD and HD just fine. Obviously, the faster the processor the better, but Dual 2.0’s work fine.
I run my Fibre Channel card in Slot 4 and the Kona 2 in Slot 3 which gives the maximum throughput for the media.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow editing “Good Eats” in HD for the Food Network
Rick Lavon
December 27, 2005 at 3:09 pmThanks fo the input. I want to swap out my Cinewave card and am in a quandry about what to get (LS or LH)…What is your opinion about the RT acceleration?…Is it noticable?…What are the pros and cons? Thanks in advance…
Rick Lavon
Rick Lavon
December 27, 2005 at 3:11 pm[walter biscardi] “I run my Fibre Channel card in Slot 4 and the Kona 2 in Slot 3 which gives the maximum throughput for the media.”
Would you recommend this setup for the ATTO Celerity card as well?
Rick Lavon
Gary Adcock
December 27, 2005 at 3:34 pm[Rick Lavon] “Would you recommend this setup for the ATTO Celerity card as well?”
YES…
the 4G card requires the 4 slot for proper performance.
Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL USA -
Walter Biscardi
December 29, 2005 at 1:48 am[Rick Lavon] “Thanks fo the input. I want to swap out my Cinewave card and am in a quandry about what to get (LS or LH)…What is your opinion about the RT acceleration?…Is it noticable?…What are the pros and cons?”
I made the swap from CineWave over a year ago. The K2 is what I wanted due to the SD to HD Up-convert which I really use a lot these days. RT acceleration really comes from having very fast drives on your system. The Kona cards do some “lifting” for the CPU to help accelerate certain functions, but you still need to have very fast drives to make it all work with the most RT.
