Activity › Forums › DaVinci Resolve › minimum requirements to run Resolve 14 and 15
Robert Withers replied 8 years, 5 months ago 7 Members · 16 Replies
Peter Chamberlain
April 21, 2018 at 1:30 pmThe minimum hardware and os requirement are clearly defined at the bottom of the read me for every release.
For your config Duke, v15 should be oh for HD media.
Duke Sweden
April 21, 2018 at 4:15 pmI’m not the one complaining about DR performance on my PC, unless you meant “ok” rather than “oh”. It works great even with 4K. I rarely have to generate optimized, just switching to half resolution playback does the trick once I start piling on tweaks.
Dell XPS 8920
Intel i7 core 7700 build
GeForce GTX 1050ti
32 Gigs of RAM
3 7200 RPM SATA Drives
Windows 10 64-bit
DaVinci Resolve 14.3 -
Bruce Watson
April 21, 2018 at 9:01 pm[Peter Chamberlain] “The minimum hardware and os requirement are clearly defined at the bottom of the read me for every release.”
So you have to download the software before you can figure out whether it makes sense to download the software? Great.
Duke Sweden
April 21, 2018 at 9:08 pmHere’s an idea. Don’t download it. Keep using what you’re using. Everybody’s happy.
Dell XPS 8920
GeForce GTX 1050ti
32 Gigs of RAM
Windows 10 64-bit
Tero Ahlfors
April 21, 2018 at 10:10 pm[Bruce Watson] “So you have to download the software before you can figure out whether it makes sense to download the software? Great.”
Actually you don’t because there’s the “read more” link next to the download buttons on the BMD support page, but you keep whining about every single thing so maybe you’ve made up your mind about it already. The readme does have some minimum specs but probably not as detailed as you would want because there are different kinds of minimum specs depending on what one is trying to accomplish. Do you want to just barely start the program? Do you want to work in HD? Do you want to work in 4K? Do you want to work in 4K in realtime? Etc.
I asked this before but if you can post your computer specs we can help you with this if trying the fully featured free version of the software is out of the question for some reason.
Robert Withers
April 22, 2018 at 12:29 amI haven’t been following the attitudes and exchanges here but yes clicking on the “Read More” links on the download descriptions does bring up a page that lists minimum and system requirements for each version. Who’d have guessed? Most software developers don’t hide their requirements so carefully. This is helpful information.
Thanks.Robert Withers
Independent/personal/avant-garde cinema, New York City
