Activity Forums Adobe After Effects Minimum line width
  • Minimum line width
    Posted by Jerry Smith on March 31, 2016 at 2:33 pm
    For a 1920×1080 composition that will be rendered in a bunch of different ways, what is the minimum safe size for a line? I read somewhere that 3 pixels was a good rule of thumb.
    John Cuevas replied 10 years, 5 months ago 2 Members · 1 Reply
  • John Cuevas
    March 31, 2016 at 2:57 pm
    If it’s progressive, you should be able to do a pixel width of 1. Unless I have good reason, I stick to 1.5 to 2 at the low end, depending on the project. I would just make a couple of quick test animations(create lines of 1,2,3, & 4 pixels wide), compress to all your deliverable formats and determine my min based on the most compressed file.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
