Activity Forums Apple Final Cut Pro Minimizing a shaky shot
  • Minimizing a shaky shot
    Posted by Fredy Schwerdtner on September 18, 2012 at 8:35 pm
    It is just a question for those who also use the cameras… not only the editing softwares …lol
    Is it possible and is it true that I can minimize the camera shaking using the settings of 720p with 60fps (instead of 1080p with 30fps) and after shooting transcode it to 30fps (29.97) for a website (internet) and for a SD DVD ?
    Thanks in advance.
    Fredy.
    iMac 2.7 GHz Intel 4 Core i5
    16 GB memory
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    6GB 667 MHz DDR2 SDRAM
    OS X 10.7.3
    FCPX
    Final Cut Studio “3”
    Fredy Schwerdtner replied 14 years ago 3 Members · 4 Replies
  • James Cude
    September 18, 2012 at 10:02 pm
    Nothing beats a tripod or a shoulder brace… fix it in production…
  • Fredy Schwerdtner
    September 18, 2012 at 10:10 pm
    They will be “b-cameras” for B-footage to be used on a video clip. Pocket Cameras like the Sony Bloggie.
    16 GB memory
    MacBook Pro 17″
    OS X 10.7.3
    FCPX
  • David Eaks
    September 18, 2012 at 11:10 pm
    I agree with James comment “fix it in production”. Don’t plan to have a problem that needs fixing, instead plan to make it good from the start. Fix any mistakes in post as necessary.
    Can you at least rig up a make shift steady cam for these little cameras? Even a mono pod with a small weight at the bottom can do wonders to help steady small handheld cameras. Extend the monopod to the ground when standing still or collapse it and move around freely. With a little practice, the weight acting as a counter balance can really help to smooth out handheld shots.
    I looked at the Bloggie. Its tripod mount is on the bottom, orienting it in portrait mode. Probably not what you want. I found one guy on youtube who built a very cheap homemade bracket to mount it in landscape orientation.
    At least if you rigged all the handheld cameras to something it would hopefully prevent anyone from shooting in portrait!
  • Fredy Schwerdtner
    September 20, 2012 at 12:52 pm
    Thanks for your words David and forgive for have not answering before.
    16 GB memory
    MacBook Pro 17″
    OS X 10.7.3
    FCPX
