Activity Forums Adobe Audition Minimize Club Music/Bass
  • Minimize Club Music/Bass
    Posted by David Jennings on November 30, 2008 at 4:09 am
    I shot some video in a club and want to minimize the heavy bass; how do I achieve this with Premiere Pro 2? – I have been messing with the EQ filter but I do not know what I am doing. Thank you in advance.
    Steven Talley replied 17 years, 9 months ago 2 Members · 1 Reply
  • Steven Talley
    December 3, 2008 at 3:42 am
    I haven’t used Premiere in years but if you have Audition you can export the audio as a .wav file and import into Audition and alter the sound there. Then save as a .wav file and import into the Premiere time line, be sure to mute the original audio in the time line when you go to render it out.
    If Premiere’s EQ filter is a graphic EQ then you should have access to controls for different ranges in the audio spectrum. Try lowering all the controls under 400Hz as needed to remove the boominess.
