Activity Forums Apple Final Cut Pro Legacy MiniDV to DVCPRO HD upconvert on the 1700?
  • MiniDV to DVCPRO HD upconvert on the 1700?
    Posted by Christian Kinnard on November 14, 2005 at 8:47 pm
    Does anyone know if you can upconvert via firewire directly into FCP from the 1700? I have a bunch of MiniDV tapes and it will take forever to bump from the 1200a deck to another. I don’t have the storage to go through the Kona card?
    Jeremy Garchow replied 20 years, 10 months ago 4 Members · 4 Replies
  • Walter Biscardi
    November 14, 2005 at 8:55 pm
    You can go through the Kona 2 card and just capture at DVCPro HD to save on storage.
    HD-SDI in to the Kona 2 using the DVCPro HD easy setup. Either K2 or the 1200A can perform the upconvert for you.
    Walter Biscardi, Jr.
    “The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
    rsvp@biscardicreative.com to reserve seats.
    https://www.theroughcutmovie.com
  • Guy
    November 14, 2005 at 11:56 pm
    Is there a difference in quality between using the 1200a versus the Kona 2 when upconverting?
  • Christian Kinnard
    November 15, 2005 at 12:38 am
    I could get it to capture uncompressed or at offline resolutions, but when going through the Kona to get the DVCPRO HD codec FCP kept crashing. Called AJA and turned out I needed a different driver. Very help full people at AJA.
  • Jeremy Garchow
    November 15, 2005 at 3:46 am
    Yes. I find the 1200a upconvert to be a little cleaner, but the Kona 2 upconvert feature is great if you don’t have the 1200A laying around.
    Jeremy
