Activity Forums Canon Cameras miniDV or HDV tapes?
  • miniDV or HDV tapes?
    Posted by Nate Hanson on November 10, 2008 at 9:18 pm
    I saw on the product description for the XH-A1 that it takes miniDV tapes. Can you use regular miniDV tapes for this camera? I assume there must be a quality difference between the HDV version of miniDV.
    Thanks for enlightening me!
    Nate*
    * Author has no real-world experience; he works in the plastic-bubble world called “Public Education”.
    William Busby replied 17 years, 9 months ago 2 Members · 4 Replies
  • William Busby
    November 10, 2008 at 10:25 pm
    This is asked quite frequently and the answer never changes…
    There’s no “quality” difference, the data is the same. The only factor is using a high grade tape will greatly lessen the chance of HDV dropouts.
  • Nate Hanson
    November 10, 2008 at 10:36 pm
    Then my follow up question is, can I use my cheaper Canon Elura 85 hand-held camcorder to transfer the tape data to my computer, rather than using an expensive camera as a tape deck? If the data on the tape is the same, it should transfer out through firewire the same, right?
    Nate*
  • William Busby
    November 11, 2008 at 12:13 am
    That’s not a HDV camera… so no, you can’t use it as a HDV playback source obviously.
  • William Busby
    November 11, 2008 at 12:17 am
    I forgot to add… you can buy a used HV10 or 20, or a new HV30 to use as a source deck and also you would have a fairly decent backup cam.
