Activity Forums Apple Final Cut Pro Legacy MiniDV Export for DVD color problems?
  • MiniDV Export for DVD color problems?
    Posted by Thomas on August 29, 2006 at 6:56 pm
    Has anyone encountered a problem where you’re exporting a miniDV project into idvd for TV viewing or for the web and the colors look a bit faded?
    I’ve exported the clips as a Quicktime compression as a “Quicktime Movie” (where it exports your clip into a FCP project file) and not “Using Quicktime Conversion”.
    I’m wondering if this is just a DVD compression? It shouldn’t effect the colors though. Even for web viewing.
    Bmeeks replied 20 years ago 2 Members · 1 Reply
  • Bmeeks
    August 30, 2006 at 1:32 am
    Yep, I have the same problem and can’t figure out what the heck is going on. Here’s the rub for me: If I put that FCP output into iDVD the color and contrast all “comes back” as it where and I have no idea why.
    To see a side-by-side example of this, take a look at the following screen shot (URL below). This shows the exported a frame from the FCP clip that I exported to a QT movie (right side of screenshot) and the same frame after the QT movie has been dragged into an iDVD project.
    https://www.meeksphoto.com/test/idvd-qtcontrast.jpg
    Now, this is no big deal if you’re always going to drag the FCP output into iDVD, but that’s certainly not the case for me; more often than not I’m developing a clip to be viewed using QT and with the washed out colors, well, it’s driving me nuts.
