Activity Forums Apple Final Cut Pro Legacy Mini-DVD Tape Playing with Noise?
  • Mini-DVD Tape Playing with Noise?
    Posted by Daniel Monskey on November 16, 2010 at 9:22 pm
    I have a lot of old Mini-DV tapes I am pulling clips off of, but I am using a different camera with which to capture (original camcorder is retired). There is pixel noise all over then, even after I have ran a cleaning tape through the camera and forwarded and rewound to help realign the tapes to the heads. What can I do to successfully capture from these tapes?
    Dan
    Daniel Monskey
    Daniel Monskey replied 15 years, 10 months ago 2 Members · 2 Replies
  • Michael Gissing
    November 16, 2010 at 10:04 pm
    Cameras are not the best playback decks. If you can hire or borrow a DSR 1500 or similar with lowish head hours, you might get a better result. Many if the HDV decks will also playback DV.
  • Daniel Monskey
    November 17, 2010 at 12:53 am
    I am now using a Panasonic AJ-SD93 deck and it is still getting some of the visual noise on some of the tapes.
    Still looking for answers on this now that I;m having problems with the deck.
    It is a multi-use deck so I am using a carousel to slide the tape into the deck—but it is meant to do this.
    Dan
    Daniel Monskey
