Activity Forums Adobe After Effects mini-dv vs. DV-Cam for greenscreen footage
  • mini-dv vs. DV-Cam for greenscreen footage
    Posted by Gene Torres on May 19, 2006 at 4:28 pm
    I am trying to choose a camera for a project that will involve some green screen shots. I can choose between a Cannon mini-dv camera or a Sony DV-CAM. I know that DV in general is not the best for greenscreen but I am trying to figure out will I get a noticable difference in choosing DV-CAM over mini-dv? Thank you for your expert advice.
    Nate Biehl replied 20 years, 4 months ago 3 Members · 2 Replies
  • Jonathan Miller
    May 19, 2006 at 4:50 pm
    For all intents and purposes, there is no difference between standard DV and DVCAM. They both have the same color sampling (4:1:1 for NTSC or 4:2:0 for PAL) and both run at 25Mbps. With DVCAM, the tape runs through the camera faster and the audio is locked to the video, but that won’t help with chromakey footage.
    If you must use one of those flavors of DV, then maybe look into a keying plug-in specifically designed to work with Mini-DV footage. Or, if you have the budget for a DVCAM camera, then maybe consider going with a consumer HDV camcorder and shooting in HD for delivery in SD. There are still problems keying HDV, but in my experience the added resolution of performing the key in HD and precomping that into an SD comp seems to really help things.
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
    Currently producing these popular podcasts:
  • Nate Biehl
    May 19, 2006 at 5:41 pm
    I did a DV greenscreen project last year, and I got a noticeable improvement in the cleanliness of the key when I changed the way I captured the footage.
    I used Apple’s Shake as my keying/compositing software, and manual recommended changing the capture settings to Uncompressed 4:4:4. I’m not sure how this change affected footage that was originally compressed at 4:1:1, but it seemed to key much cleaner with a lot less aliasing than my first attemts that were captured at DV compression.
    The files were ENORMOUS, though, (sorry, I don’t remember exact numbers, but they were much larger than the 4:1:1 files) so consider your storage and rendering limitations if you want to try this. I spent a lot of time trying to explain why the project was taking so long.
