Activity Forums Panasonic Cameras mini dv tape question(s)
  • mini dv tape question(s)
    Posted by Fred Estabrook on September 11, 2006 at 6:25 pm
    1st – i’ve heard that you should always use the same brand of mini dv tape in your camera – because some have wet and some dry lubricant and that it’s bad for the camera to switch between them… is this a real concern? 2nd – are 80-minute mini dv tapes more prone to problems and therefore not recommended (as with 90 and 120-min. audio tapes)? thanks.
    Fred Estabrook replied 19 years, 11 months ago 2 Members · 2 Replies
  • Noah Kadner
    September 11, 2006 at 8:48 pm
    Yes on both accounts- pick one tape and stick to it, avoid the extra long loads if you can. I’ve always used the Panasonic AY-DVM63MQ Master Quality tapes.
    Noah
  • Fred Estabrook
    September 12, 2006 at 3:29 pm
    Noah – Thanks! I’ve heard conflicting views on this (even from pros) but your advice will be followed (from now on).
