Activity Forums Apple Final Cut Pro Legacy Mini-DV Tape Ingestion
  • Mini-DV Tape Ingestion
    Posted by John White on October 3, 2011 at 7:36 pm
    I recently shot a musical performance with three cameras – each a different manufacturer – on Mini-DV tape. Here’s my question: to save wear and tear on each camera, I’d rather use a Mini-DV deck to ingest tapes into Final Cut. But I have advised it might be cheaper to just purchase an inexpensive Mini-DV camera to use for playback only. However, when I have tried that in the past, I’ve found that a tape recorded on one brand of camera won’t play back on another brand, i.e. a tape recorded on a Canon camera won’t playback on a Sony camera. So, do I buy a Mini-DV deck or a cheap camera? Suggestions? FYI this is SD but may be HD down the line. Thanks.
    Everest Mokaeff replied 14 years, 11 months ago 2 Members · 3 Replies
  • Everest Mokaeff
    October 4, 2011 at 10:19 am
    Take a look at panasonic – it usually playbacks fine tapes from sony or canon. Test your tapes before purchasing.
    Sony PMW-EX3, Canon Mark II 5D, FCS3 in Moscow
    http://www.mokaeff.com
  • John White
    October 4, 2011 at 1:04 pm
    Thanks, but did you mean a Panasonic camera or deck?
  • Everest Mokaeff
    October 5, 2011 at 8:40 am
    I meant camera, though it’s kind of hard to find cheap one on market since they’re discontinued long time ago. If you’re looking for a deck buy pro level sony, it’ll work with all tapes.
