Activity Forums Apple Final Cut Pro Legacy mini DV capture problem
  • mini DV capture problem
    Posted by Annu Lilja on July 16, 2010 at 5:26 pm
    I have Final Cut 6.0.4. on my Mac Book Pro. Trying to capture mini DV using a Sony DV/HDV recording deck. When trying to start log and capture, it says it cannot initialize the deck. This is when I have it set on Firewire NTSC. When I have the deck set as HDV, I can control the deck from my FCP, but I still can’t capture the tape, probably because it is mini dv, not hdv. What is wrong?
    Chris Tompkins replied 16 years, 1 month ago 2 Members · 3 Replies
  • Chris Tompkins
    July 16, 2010 at 6:00 pm
    Did you try using an easy setup?
    Chris Tompkins
    Video Atlanta
  • Annu Lilja
    July 16, 2010 at 6:06 pm
    Yes
  • Chris Tompkins
    July 16, 2010 at 6:09 pm
    Make sure ur deck is set to output DV and NOT HDV.
    Then shut down comp and deck.
    Then turn on deck. Boot up comp.
    Launch FCP.
    Chris Tompkins
    Video Atlanta
