Activity Forums Blackmagic Design Mini Converter Question
  • Mini Converter Question
    Posted by Sean Oneil on May 11, 2008 at 8:07 pm
    If I get a SDI to HDMI mini converter, can I use it as just a SDI Audio de-embedder? Will the sound still work even if nothing is plugged into the HDMI port?
    Kristian Lam replied 18 years, 4 months ago 3 Members · 3 Replies
  • Bob Zelin
    May 12, 2008 at 1:44 am
    I would assume that the answer is YES to this, as this is how all other converters work (all outputs active, weather you use them or not). And at $495 retail, (and it will be cheaper mail order), this is a damn good price.
    Bob Zelin
  • Sean Oneil
    May 12, 2008 at 2:04 am
    The prices are amazing. Especially the sync generator.
    Sean
  • Kristian Lam
    May 14, 2008 at 7:34 am
    Hi Sean,
    This is correct. The audio output will still work even nothing is plugged into the HDMI output port.
    regards
    Kristian Lam
    Blackmagic Design
