Activity Forums Adobe After Effects Millions vs Trillions in 8 bpc
  • Millions vs Trillions in 8 bpc
    Posted by Engin Osmanovski on September 2, 2014 at 2:17 pm
    I rendered out a frame of my composition twice for comparison: One as PNG, 8bit and Millions of Colors selected. The other one as PNG, 8bit and Trillions of Colors selected. When i compared the two results, i couldn’t see any visual difference. But Trillions of Colors version is 2 times larger than the other one (in terms of file size). So what is the point of rendering out with 8bits+Trillions of Colors if there will be no difference in visual quality? Why use Trillons of Colors with 8 bit?
    The example images i am talking about can be downloaded from below:
    https://www.filedropper.com/8bitmillionsofcolors
    https://www.filedropper.com/8bittrillionsofcolors
    Walter Soyka replied 12 years ago 2 Members · 1 Reply
  • Walter Soyka
    September 2, 2014 at 4:23 pm
    [Engin Osmanovski] “So what is the point of rendering out with 8bits+Trillions of Colors if there will be no difference in visual quality? Why use Trillons of Colors with 8 bit?”
    There is no point to outputting Trillions of Colors for an 8b project.
    Output Trillions of Colors when you want to preserve the color depth in an a 16b project. Output Floating Point when you want to preserve the depth in a 32b project.
    If you output at a lower depth than you are working (for example, working 32b float but outputting Millions of Colors), Ae will apply some dithering for you for smooth-looking results. You will preserve the same appearance you had on your monitor, but of course the output depth is lower and overbrights and superblacks are clamped.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
