Activity Forums DaVinci Resolve Migrating project with LUTs that are no longer installed
  • Migrating project with LUTs that are no longer installed
    Posted by Toby Tomkins on August 27, 2013 at 1:27 pm
    I have an old project that used some LUTs that I no longer have installed, which I am trying to migrate over to a new machine.
    I have tried moving the entire database (via backup/restore) and also exporting the project (ticking the LUT box when doing so). Neither methods seem to migrate across the old LUT.
    Any ideas?
    Toby
    Eric Johnson replied 13 years ago 2 Members · 4 Replies
  • Toby Tomkins
    August 27, 2013 at 2:58 pm
    It’s worth noting I applied the old LUT via a node and despite the LUT not being installed anymore, is still being aplied by the node in the old project!
  • Eric Johnson
    August 27, 2013 at 4:44 pm
    Are you not able to create a LUT from a Node/Correction? If the non existent LUT is still being applied correctly, you could try opening the project in “Read Only” mode, disabling all corrections but the LUT and generating a new one…
    May not work, but if it does you have the LUT you no longer have…
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/39073239
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Toby Tomkins
    August 27, 2013 at 5:03 pm
    I thought of that but I’ve never found DaVinci’s LUT generation to be 100% reliable, especially when using a complex 3D LUT like this one (Alexa LogC to Technicolor Vision 3 250D log film scan LUT, that’s increasing colour separation and is fragile as-is, without DaVinci ripping it which might introduce further problems). I’ll give it a go if there’s no other way and report back.
  • Eric Johnson
    August 27, 2013 at 5:24 pm
    What about stripping everything but the LUT and saving the Node to the Still Store?
    eric b johnson
