Activity Forums DaVinci Resolve Middle Mouse Button
  • Middle Mouse Button
    Posted by William Edwards on February 15, 2012 at 2:02 am
    Hello,
    I tried using the middle mouse click, but it doesn’t seem to work. I’m running Resolve Lite on MacBook Pro, the mouse is a Logitech ‘Anywhere’ mouse. I configured the mouse to have a center button on it as a middle mouse click. I tried programming the other mouse button for this as well, to no avail.
    Any ideas on how to get this working would be appreciated.
    EDIT – Tried setting a bamboo tablet with middle mouse click. That doesn’t work either. Am I missing a setting in Resolve?
    Brandon Thomas replied 14 years, 7 months ago 4 Members · 4 Replies
  • Ron Nichols
    February 15, 2012 at 3:09 am
    Here is a download for the “logictech control center” for OS X, this will allow you to configure your mouse and hopefully solve the issue.
    https://www.logitech.com/en-us/584/3129
  • William Edwards
    February 15, 2012 at 5:03 am
    Thanks Ron, but I have that, and I tried on a wacom ‘bamboo’ tablet. Same thing, with the middle mouse button not functioning.
  • Juan Salvo
    February 15, 2012 at 5:54 am
    Is your Middle mouse button set to button 3 in system preferences? Is some other action dashboard or expose set to use the middle mouse as a trigger?l
  • Brandon Thomas
    February 16, 2012 at 4:39 am
    For the Wacom-
    Make sure the middle click is programmed in the Wacom Control Panel under System Preferences. Also be sure you have Hover Click enabled under Options in the Wacom Control Panel.
